any ideas on e4od problem?
Old Dec 8, 2002 | 09:48 AM
capt scott's Avatar
capt scott
short background, f350 7.3 turbo diesel, e4od. had tranny replaced with rebuilt unit 2 years ago. it developed a growling noise when pulling a boat trailer. noise would come and go according to throttle pressure around 60. mechanic that installed it said the planetery gears were going out. it was out of warranty. so i looked for a more reasonable option. found a "good used" tranny with only 15k miles out of a wreck. like the other tranny, operates perfectly when it is just the truck. just towed a boat for the first time since putting in the new tranny and it does the same thing as the previous one!!!! am i missing something here? replaced u joints etc while trying to diagnose the previous tranny troubles. can my luck be so bad as to get 2 in a row with planetery problems?? i am so fustrated with the e4od that i am considering a switch to manual. thanks for any ideas!!
Old Dec 10, 2002 | 06:43 AM
rabidranger's Avatar
rabidranger
Could it be the rearend? Maybe you need new gears.
Old Dec 10, 2002 | 05:47 PM
capt scott's Avatar
capt scott
thanks for the reply. guess it is possible. i am thinking of checking the entire driveline before pulling the tranny again. replaced u-joints with the previous one with no change though. pinion was tight. will pull the cover and see if anything shows.
thanks again.
Old Dec 14, 2002 | 05:35 AM
spacecoast's Avatar
spacecoast
Old Dec 15, 2002 | 10:03 AM
gregdatech2's Avatar
gregdatech2
DOnt rule out the pinion bearing just because its tight. Look at those gears and the wear pattern. SOunds like a rear end problem to me.
Old Dec 15, 2002 | 08:52 PM
stuarta's Avatar
stuarta
If the noise occurs at 60 mph it is not the planetaries.
Old Dec 15, 2002 | 10:21 PM
capt scott's Avatar
capt scott
thanks for the ideas. i have a few days off over christmas and will check out the rear end then. if you have any other ideas, i am standing by. it really seems funny to me that the growling comes and goes and is only when towing. thanks again for any help.
scott
