Stuck in gear
Old Apr 14, 2009 | 02:05 AM
dustybb01's Avatar
dustybb01
Stuck in gear
My 66 f100 with a 351w and three on tree is stuck in 1st gear. Stopped after a 5 mile drive and when i restarted the truck it wouldnt come out of first. Any ideas on how to free it? <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Apr 14, 2009 | 02:18 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
dustybb01
I replied to your other post ,if it helps post back if it does it again you may have to ( ALINE ) the linkage !
Link from the Bumpside Forum>>>>>>>>>>>>
https://www.ford-trucks.com/forums/8...irst-gear.html
Wally Womack
Last edited by Pro-Street/StateTK; Apr 14, 2009 at 02:21 AM. Reason: watching my Ps and Qs
Old Apr 14, 2009 | 02:23 AM
Bill W's Avatar
Bill W
more than likely the bushings on the shift rods are worn out or missing..... try to free it at the tranny levers from under the truck, AND make sure the Ebrake is *ON* before you go under it, My 63 econoline used to hang up ALL the time, almost ran myself over once when it came free on an incline.
Good Luck.
Old Apr 14, 2009 | 09:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
At the bottom of the steering column under the hood are the two manual control selector levers where the shift rods from the transmission attach.
In each one of these levers is one rubber bushing and insulator. When the rubber bushings crack apart, the shift lever binds up.
C5TZ7343A .. Bushing & Insulator Kit / One kit does both levers / Available from Ford.
MSRP: $30.73 // FTEpartsguy.com price: $22.13.
This is a very common problem that affects all 1965/79 F100/350's. The same kit fits all these trucks.
sddesigns
New Jersey Chapter
May 5, 2010 06:29 AM
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
sddesigns
New Jersey Chapter
Jan 28, 2010 05:46 PM
