FRONT SPIDER GEAR WELDING?????????????
Old Dec 11, 2002 | 12:32 PM
GOT NOS's Avatar
GOT NOS
I WAS WOUNDERING IF IT WAS REALLY THAT BAD TO WELD THE FRONT END BECAUSE ALL I DO IS GO PLAY IN THE MUD AND SAND AND A LITTLE BIT OF ROCK CRAWLING BUT NOT MUCH AND I WELDED TO REAR AND I WANT TO WELD THE FRONT.
Old Dec 11, 2002 | 12:42 PM
heathdaily's Avatar
heathdaily
I ain't a four-wheeler, but I'm pretty sure that'd make it steer REAL funky like.
Old Dec 11, 2002 | 02:33 PM
AggiePSD's Avatar
AggiePSD
you could not steer at all on any kind of decently hard surface. not on pavement for sure, or even on packed dirt, etc. in mud or soft ground you would probably slide more than you would steer. i would not even consider it, lockers up front at least unlock when you try to turn.
Old Dec 11, 2002 | 04:20 PM
85351ho's Avatar
85351ho
its not bad if your short on cash and you dont mind getting out and unlocking one hub to turn. I usually run with one hub locked till it gets nasty then get out and lock up. I have a front detroit in the near future im gonna put in there, but i figured i would give it a try. Also be prepeared to break more axle shafts
Old Dec 11, 2002 | 10:39 PM
steve83's Avatar
steve83
It shouldn't hurt anything if you have manual hub locks - just run 3WD if you have to do it on-road (snow, ice). The steering may pull a little to the locked side, but it'll be better than 2WD. Off-road, it'll be fine.
Old Dec 16, 2002 | 05:36 PM
sprice's Avatar
sprice
Post FRONT SPIDER GEAR WELDING?????????????
I put a spool in the front of mine, it locks both axles together same as welding. I would not do it again, it does not steer even on dirt roads, it's only good for mud or total slop. I would put a detroit, or some type of limited slip if I had it to do again.
Old Dec 16, 2002 | 06:13 PM
joetee10's Avatar
joetee10
