transmission swap
Old Apr 13, 2009 | 07:21 PM
fordboyoffroad's Avatar
fordboyoffroad
transmission swap
is a 1989 ford 2.9 5 speed transmission compatible with a 1994 ford ranger 4.0L
Old Apr 14, 2009 | 09:03 AM
BSmitty's Avatar
BSmitty
Should work, bellhousing is the same. The only thing to watch out for is which trans is in the '89. There were 2 transmissions available in '89 behind the 2.9l. The Mazda M5OD R1, and the Mitsubishi FM146. Look at the bottom of the trans body, if it has a removable pan it's the Mitsu. If it's a 1-peice body with no pan, it's the Mazda. The '94 will have the Mazda. Supposedly they will interchange, but sticking with the same family will keep you from having all those annoying little interchange hangups.
Old Apr 14, 2009 | 04:34 PM
Pablo-UA's Avatar
Pablo-UA
Yes, but 4.0 tranny is enforsed a bit, so do not drive aggressively and do not tow/haul too heavy things
Old Apr 25, 2009 | 05:57 PM
fordboyoffroad
time fly scory about the time delay im ben besy and thanks for the inpout but ive been having other problms with this truck at thes time so the trans will hav to weat. i probly shod fine a thuck with a 4.0 in to get the trans out of becous ti's get work hard
