Cab corners-93 super cab
Old Apr 12, 2009 | 09:35 AM
mkrog's Avatar
mkrog
Question Cab corners-93 super cab
My 93 has a rust hole in the rear cab corner on the right side.I got a replacement panel from LMC that goes from the door jamb around to the back of the cab and from under the cab up about 12.5 in.You guys most likley know what there like.My question is should I use the whole patch panel or just use what I need,also can this be done with out removing the box?
Old Apr 12, 2009 | 03:11 PM
wendell borror's Avatar
wendell borror
You'll just about have to pull the box to do it correctly. The amount of patch pannel you use is totally up to you, just make sure you get all the bad area.
