DRIVE LINE PROBLEMS
Old Dec 27, 2002 | 12:43 PM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
My ford drive shaft viberats when i go from a dead stop. I have 6" lift & Blocks in back. What could it be.
Old Dec 27, 2002 | 03:46 PM
blownbronco's Avatar
blownbronco
DRIVE LINE PROBLEMS
It's time to change your rear U-joint. Also when you change it make sure the drive shaft angles are not too extreme! Let us know how it turned out!!
Old Dec 30, 2002 | 02:16 PM
fsnco1's Avatar
fsnco1
DRIVE LINE PROBLEMS
You're right. Never hurts to change those rear u-joints. also the higher you lift the truck, the more of an angle you get on the shaft and "axle wrap" occurs. it is more like a clunk although it can shudder a bit too.
Old Jan 1, 2003 | 04:45 PM
78bronco's Avatar
78bronco
DRIVE LINE PROBLEMS
