What to do??
Old Apr 11, 2009 | 11:22 PM
farmlucki's Avatar
farmlucki
What to do??
My problem is with my shocks, or I believe it is. I started to notice that everytime I put something like my 4 wheeler in the bed of my truck it tends squat a little. Or if I stand in the bed of my truck the shocks seemed to compress pretty easly. my psd is only a 2wd f-250. Just wondering if you think i need new shocks. No springs are broke. Also putting on new shocks would that raise the rear end up a little.
Thanks Keith
Old Apr 11, 2009 | 11:41 PM
maadman's Avatar
maadman
If you can feel your shocks compress when you get in the back and you can bounce the bed, then it is definately time for new ones.
Old Apr 11, 2009 | 11:45 PM
PwerStroke99's Avatar
PwerStroke99
how old are the shocks??? if they are still the factory shocks, then yes i would change them out. i would recommend Bilsteins.
Old Apr 12, 2009 | 12:05 AM
farmlucki's Avatar
farmlucki
they are factory shocks, so I guess i'll get some new ones. is there a heavy duty shock out there that you would recommend.
Old Apr 12, 2009 | 03:44 AM
ron's power stroke's Avatar
ron's power stroke
Old Apr 12, 2009 | 04:29 AM
Kwikkordead's Avatar
Kwikkordead
If your truck is squatting under a load, the shocks won't fix that.
All the new shocks will do is keep it from bouncing up and down excessively after hitting some dips in the road.
They don't actually carry any weight, but rather are motion dampers.
Old Apr 12, 2009 | 07:38 AM
F350-6's Avatar
F350-6
Well said, but if you're running factory shocks, YOU NEED TO REPLACE THEM.
They won't raise the truck up, or keep it from squatting though. You'll either need to add a set of overload springs, replace the springs, get them re-arched, put in a set of airbags or timbrens to address the squatting.
You'll be amazed how much better the truck rides with new shocks, so start there. That will put you in a better mood while you decide on what to do about the springs.
Old Apr 12, 2009 | 07:44 AM
zx250's Avatar
zx250
Of the next Riffraff East
Time for some air bags. Springs will weaking over time and like any old rearend, they sag. (:
Old Apr 12, 2009 | 09:00 AM
togobefastguy's Avatar
togobefastguy
yeah i agree the shocks wont help the sag. but if you decide to get shocks you can get them at shockwarehouse.com 190 something for my blistens
