Which front axle?
Old Dec 30, 2002 | 08:55 AM
tomw's Avatar
tomw
Which front axle?
Old Jan 1, 2003 | 08:13 PM
first time 4x4's Avatar
first time 4x4
Which front axle?
I would like to get a locker or limited slip for the front of my truck. I'm not sure if I have a Dana 44HD or a Dana 50. How do I tell? The rear is a 10.25 full floater and the truck is a 1991 F250.
It is not a F250 HD. It is probably easy to distinguish the two axles, I just dont know how. Also when I find out what axle it is what is a good locker. I just got a Detroit in the rear on Christmas Eve and there is no way that i want that up front. The front axle is one of those TTB's if that helps.
Old Jan 1, 2003 | 08:34 PM
DCSpecial's Avatar
DCSpecial
Which front axle?
Its the Dana 50 TTB on the F 250.
Are you sure you want another locker up front? You said you don't want something up front like your detroit in the rear.
So, I'd say either go with a selectable locker or a good limited slip up front depends on how much money you want to spend and how you're going to use the truck.
Hope this helps
Old Jan 1, 2003 | 08:50 PM
82F100SWB's Avatar
82F100SWB
Which front axle?
With a LD, the 44HD is most likley, however, a D50 is possible, AFAIK, the housing should have 44 or 50 cast on the bottom, my 50 does.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 8800LB GVWR 460/Edelbrock 1411
T19/BW 1345/3.55 geared Full Floater 10.25/Dana 50 TTB
265/75R16's on Whitespokes
I'm just your average 18 year old... LOL
Old Jan 1, 2003 | 08:57 PM
DCSpecial's Avatar
DCSpecial
Which front axle?
>Evan
Good call, I guess it helps if I read the part that says NOT a HD.
