Backup lights
Old Apr 11, 2009 | 06:06 PM
priusron's Avatar
priusron
Backup lights
2001 F250 fuse 28 blows whenever I put it in reverse.
Most likely cause.
thanks
Ron
Old Apr 11, 2009 | 06:36 PM
megawatt00's Avatar
megawatt00
Dead short. Look for pinched or exposed wires around the rear bumper area. There may be a T connector that goes to each light that you can unplug to isolate each side.
Old Apr 11, 2009 | 07:29 PM
danskool's Avatar
danskool
Go Bills !
I had trailer plug receptacle short out and starting smoking up the garage. Never popped the fuse. Melted the whole plug.. All the wire connections were caroded.
#28
Brake Shift Interlock, DRL Relay Coil,
Speed Control Module, Backup Lamps,
Trailer Tow Backup Lamp Relay Coil,
Electronic Shift On The Fly Hub Lock
Solenoid, Vacuum Pump Motor
