C5 sloppy upshift
Old Dec 27, 2002 | 06:28 AM
sailing131's Avatar
sailing131
C5 sloppy upshift
I have a 1984 F150 4.9 liter 300/6 with a C5 automatic transmission.
When it shifts from 2 to 3 the up shift is very sloppy the engine rpm’s creep up and then it thumps into third gear. If I am gentile with it is less severe. I have been working on this problem for some time. It’s really not a performance issue it’s just an inconvenience. The transmission has 195,000 miles on it and has never been in the shop. I have changed the transmission fluid religiously every 30,000 miles.
To try and correct this problem I have
* Adjusted the bands, no improvement.
* Replaced all vacuum hoses from the vacuum modulator valve to the manifold. No improvement.
* Replaced the vacuum modulator, no improvement.
* Adjusted the kick down linkage. No improvement.
When I kick the transmission down from 3rd to second it downshifts fine but then has the same problem shifting up again.
Any help on this would be greatly appreciated.
Old Dec 29, 2002 | 10:58 PM
gregaust's Avatar
gregaust
C5 sloppy upshift
You could try one of the transgo basic type shift improver kits which can rectify some problems and improve the shifts.It sounds like you might have a 2-3 flare which is common on c4/c5's.The prob might be caused by wear in the direct clutch pack with that mileage on it..
Old Dec 29, 2002 | 11:30 PM
Chas1234's Avatar
Chas1234
C5 sloppy upshift
The c5 also has a lockup torque converter they tended to have alot of problems .I wouldchange it out for a c4 converter. That is the only differnece between the two trannys
Good luck , Jon
Old Jan 6, 2003 | 07:38 PM
transman_289's Avatar
transman_289
C5 sloppy upshift
3rd gear clutches are probably worn because of the lockup converter. The c-5 (only) has a wave plate to apply 3rd softly and prematurely burns up 3rd clutch but with this many miles this is not prematurely and also can't change C-5 converter to C-4 converter because bellhousing on C-5 is about 1 inch thicker than C-4 you can buy a C-5 converter with lockup feature taken out at local trans shop.
Lloyd
Old Jan 6, 2003 | 07:41 PM
transman_289
C5 sloppy upshift
you can also try a slightly tighter 2nd (front) band adjustment back it out 1-1/4 to 1-1/2 turns.
Lloyd
Old Jan 6, 2003 | 09:02 PM
TailGater_73F100's Avatar
TailGater_73F100
C5 sloppy upshift
LARIAT 85
'80-'86 HOWTO's
33
Apr 24, 2026 09:07 AM
86Bronco6
1978 - 1996 Big Bronco
Jun 11, 2012 06:29 PM
Hybrid455
Sep 6, 2009 07:08 AM
cnajp
Aerostar
Nov 9, 2004 11:45 PM
