help on ford brakes
Old Apr 9, 2009 | 08:30 PM
JChimbolo's Avatar
JChimbolo
help on ford brakes
I have a 69 Ford F100 Good Humor Truck. I was told everything suspension is F250.
From LMC truck I bought 2wd Wheel cyl and brake master. I have a brake booster. All drums.
I can not get the lines bled. Do I have this set up correct?
A) the master came with a new push rod. Do I need to install this?
B) is the front most master port for the rear or the front?
C) one line has a big 1/2 inch or so 3/16 line fitting, the other has a smaller one with an 1/2 inch adapter. Which port gets the adapter and which gets the direct line. Does anyone make new fittings this size?
D) on the dist block, on the front side, is the top most port to the front or rear
Old Apr 10, 2009 | 10:53 AM
frankensteined_67's Avatar
frankensteined_67
did you manually bled the new brake master cylinder before you put it on. if not you are just pumping air in to the system.
A)if your push rod looks good then no. but if its no haste to put the new one in. why not us new parts (you did pay for them).
B) the larger of the reservoirs is for the front. the smaller of the two is for the rear.
Old Apr 10, 2009 | 01:32 PM
JChimbolo's Avatar
JChimbolo
Master
This may seem dumb, but how do you manually bleed a master cyl?
I always just put them in and put in fluid, either way I always thought fluid would just pump through.
Old Apr 10, 2009 | 10:12 PM
frankensteined_67
iv always put it in a vice and then used a punch or the push rod and simulate braking until it is fully primed. you don't need to fill it all the way up just put in enough to go over the distribution holes.
just a thought have you pulled off the brake lines from the master to see if it is the prob. or if it is in the proportional valve?
Old Apr 15, 2009 | 04:44 PM
frankensteined_67
did you get your brakes to work properly?
Old Apr 15, 2009 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you have an F100, the wheels are 5 lug with a 5.50" bolt circle.
The front drum brakes are 11 x 3, the rears are 11 x 2 1/4.
F250's have 8 lug wheels on a 6.50" bolt circle.
F250's have TWO different sized drum brakes, it depends on the GVW.
Some are 12 1/8 x 2 front/rear / Some are 12 x 2 1/2 front/rear.
All 1967 Ford vehicles with drum or disc brakes have a brake proportioning valve.
It can be mounted either adjacent to the steering gear box, or inboard of the left front wheel mounted on the frame rail.
Old Apr 20, 2009 | 07:14 PM
JChimbolo's Avatar
JChimbolo
Done
I ended up making a spacer to take up the slack of the plunger, it seems like a piece must have been in the old master which I threw away. The brakes are perfect.
ericconn
20
Jan 24, 2026 03:34 PM
tractormanbill
18
Jan 6, 2014 10:36 PM
1970RedF100
Apr 4, 2013 03:28 PM
cana55
May 9, 2009 07:39 AM
JChimbolo
Connecticut Chapter
Apr 20, 2009 07:11 PM
