Fuel Pressure Question
Old Apr 9, 2009 | 05:56 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
How much fuel pressure should I have on my '94 351. At idle, I have about 32-34 PSI and when I rev it up a little bit, it drops to around 30 PSI. Is this normal? I could not find the specs on my fuel pressure. Any help would be great.
Old Apr 9, 2009 | 06:10 PM
mikehawk's Avatar
mikehawk
When you measure at idle, pull the vacuum line off the pressure regulator. That should make the pressure jump about 10psi.
Old Apr 9, 2009 | 06:15 PM
1994 F250: 351, C6
Thanks, it jumped up to about 40 PSI with the vacuum line unplugged. It still drops about 4 or 5 PSI when I throttle it up a little bit and hold it. Is this a sign of my fuel pump dying? The pump in my rear tank is dead, and I would be concerned if the front pump was about to go T.U.. Also, I plan on replacing the pump in the rear tank in the next few weeks, anyone know of a good place to buy one?
