Vacuum diagram needed
1977 F250 4x4 w/ 351m
Manual Trans, no AC
Non-Catalyst, 8100 GVWR
Produced in San Jose, CA
The tag on the valve cover is mostly gone, in trying to make it our I think it says
C 71
R 0
S 12
Like I said it is pretty faded/stained and I can really make it out clearly so open to interpretation. Any help would be appreciated.
Farmengineer
VACUUM:
On the lid itself, there are two vacuum ports. One port is routed from the manifold vacuum tree. The other one goes to the vacuum motor that operate the flap. In between the vacuum motor and the port on the lid, there needs to be a delay valve installed. On the housing just north of the vacuum motor duct, there are two ports. This is a part of the emissions system. Your application may or may not have this.
The passenger side valve cover has an opening for the PCV system. This needs the crankcase breather filter installed. It filters fresh air into the engine via the passenger side valve cover.
