need a turbo upgrade?
Old Apr 8, 2009 | 06:20 PM
WMDPSD's Avatar
WMDPSD
Well I just pulled the turbo off my buddies 04 psd, he wants to know which way he should. The housing is good but both the wheels are bent up. and the bearing is out. He is not sure if he should just get the replacement turbo or the center section from ford or get something a little better from somewhere else. Its a f-350 w/ 121000 miles. 6spd, 4x4, extended cab shortbed. It has the egr unhooked, 4 in. MBRP turbo back muffler delete, edge evolution. does anybody have any suggestions on which way he should go?
Old Apr 8, 2009 | 06:56 PM
Lubbockguy1979's Avatar
Lubbockguy1979
probably not going to notice alot of improvements untill the edge is gone.... they make upgraded turbo wheels. not meant as a insult but you know the vanes move right? it is a variable vane turbo
Old Apr 8, 2009 | 07:14 PM
WMDPSD's Avatar
WMDPSD
what are you talking about edge gone? vanes move? I was asking if there is an upgrade that is not going to break the bank but give him better spool up.
Old Apr 9, 2009 | 12:35 AM
Lubbockguy1979
Edge will not be able to tune for a different turbo. The vanes on the turbo are designed to move..... It is a vvt turbo.... And yes a upgraded wheel is avalible. Do some searching all three topics
Old Apr 9, 2009 | 10:03 AM
Dustball8504's Avatar
Dustball8504
He could put a hybrid vgt turbo on from innovative if he wants to keep it that way...
