help guys
Old Apr 8, 2009 | 05:16 PM
sckootter16's Avatar
sckootter16
help guys
ok guys I have a 81 ford f-150 I just put a 4 inch lift on the truck (suspension)I am runnin 33x12.5 tire I have aproblem now with my truck swaying and steering wondering. I am asking if there is anything i can do to fix this?O all my steering parts are new except for the gear box and balljoints
Old Apr 8, 2009 | 08:35 PM
uncle.stosh's Avatar
uncle.stosh
Did you have the truck re-aligned after you installed the lift?
Old Apr 9, 2009 | 06:44 PM
skysoldiervn's Avatar
skysoldiervn
Steering
Does your truck have a front steering stabilizer shock running across the front from side to side. This helps alot.
Old Apr 9, 2009 | 07:55 PM
uncle.stosh
Not if your toe is all caddy whompus.
Steering stabilizers only mask problems, they don't fix them.
Old Apr 9, 2009 | 10:30 PM
sckootter16
no I havent had it alighned yet and yes I have a steering stabilizer. I also want to know what do you torqe the inner tie rod and drag link at? (refurring to the castle nuts on each end) thanx any info will help.
Old Apr 10, 2009 | 05:10 PM
1 F150dude's Avatar
1 F150dude
Just take it to the alignment shop and they will take care of all that when they align it.
