Do my own U Joints???
Old Apr 8, 2009 | 04:05 PM
LLOYDJOHN's Avatar
LLOYDJOHN
I have an '87 F250. I also have a junk yard front drive shaft that needs new Ujoints. I think I am handy enough to use a vise w/ a socket etc. to press out the old U joints as the shop manual says,etc., but then it talks about balancing the shaft,etc. and that sounds WAY beyond me. Do people have success doing their own,or should I bite the bullet and take it to a shop? Thanks for the real world advice,
LLOYD
Old Apr 8, 2009 | 04:35 PM
Mustangfreak86's Avatar
Mustangfreak86
Just replace the u joints. The shaft is already balanced. I don't have a vice so I beat mine out with a hammer and a 3/4 socket. You might have to beat on yours to if there rusted.
Old Apr 8, 2009 | 04:48 PM
deeznuts822's Avatar
deeznuts822
Or get a ball joint press. They are around 30 bucks at harbor freight. Makes doin u joints a breese
Old Apr 8, 2009 | 04:54 PM
lew52's Avatar
lew52
A vise or small press works good... A hammer never heard of that one...I allways mark the shaft & yoke so they go back in the same way..I never had a problem with balance..Lew
Old Apr 8, 2009 | 05:26 PM
baldboyford's Avatar
baldboyford
I agree with all of the above. It's aready balanced, vise or press are the best tools, but I've also had to use a hammer and socket before because of rust and corrosion. Oh, and like Lew52 says, mark the shaft and yoke so it goes back together the same way it came apart.
Old Apr 8, 2009 | 06:25 PM
HrdDrv's Avatar
HrdDrv
Marking the yoke/shaft is called 'Timing'. On a shaft pulled from your truck, mark the relation of the shaft to the rear yoke when pulling the main shaft, if you do that.
