whats the red thing ?
Old Apr 8, 2009 | 04:02 PM
Red Cobra's Avatar
Red Cobra
it seems everytime i fix a fuel leak another one starts... and i think the red thing is whats leaking this time ... do these things have a weeping hole like a water pump telling you that you need a new one? i hope not cuz i looked at the price of them and not cheep
Old Apr 8, 2009 | 04:11 PM
axe_handle's Avatar
axe_handle
It covers a bold. My understanding is that it is a "do not adjust this" cover.
Old Apr 8, 2009 | 08:11 PM
Red Cobra's Avatar
Red Cobra
ahh then why would it be leaking ? or is there something that leaks around this that im missing ?
Old Apr 8, 2009 | 10:34 PM
chris1066's Avatar
chris1066
There is a bolt with a jam nut under that cover. The jam nut should have a o'ring under it. Like stated above it is one of those do not adjust things unless you have been around a few of them. That bolt is also a guide for the govenor spring so if you remove it you better take off the top cover and make sure the spring stays in the proper spot.
Old Apr 9, 2009 | 01:40 AM
Red Cobra's Avatar
Red Cobra
soo all in all something that i should not touch that sucks
Old Apr 9, 2009 | 05:02 AM
PLC7.3's Avatar
PLC7.3
Visit a diesel injection shop and see what they can do to fix it.......
At 230K miles your due for a new IP and injectors most likely anyway...... Buy them online if you MUST get them and intend to do the R&R yourself.
Old Apr 11, 2009 | 08:16 PM
ford trans tech's Avatar
ford trans tech
that bolt sets the governor limit
get it out of adjustment and you can over rev the engine
it does have an o ring seal and it supports some internal parts
see a fuel injection shop
