Sponsored by: Real Truck
hubs not unlocking
Old Apr 8, 2009 | 02:59 PM
2006ford's Avatar
2006ford
hubs not unlocking
Have a F250 hubs in auto position and switch seams to be operating OK but the hubs do not seem to be unlocking all the way could this be a vacuum leak or a solenoid problem?
Old Apr 8, 2009 | 03:13 PM
Downriver Thunder's Avatar
Downriver Thunder
Did you back up at all? Sometimes you have to back up to get them to release.
Old Apr 8, 2009 | 03:17 PM
peters_f350's Avatar
peters_f350
Yeah I agree you should try backing up.
Old Apr 8, 2009 | 03:24 PM
2006ford's Avatar
2006ford
hubs not unlocking
I did back up and no luck, checked fuses, and tried putting it in and out again no luck. jacked the truck and turned the front drive shaft still wants to turn the wheels.
Old Apr 8, 2009 | 05:44 PM
eightrac's Avatar
eightrac
Sounds like you need to clean and regrease your hubs.
Old Apr 8, 2009 | 05:48 PM
74baja's Avatar
74baja
Check out:Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page This is Guzzle's Auto-hub page. I did it a few months ago. Really easy after you get the auto lock hubs off.
Old Apr 8, 2009 | 06:24 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Either the hubs themselves aren't unlocking, or the "inner spindle bearings" are dry (inside the wheel bearing, where the axle stub goes through)
