Another issue
Old Apr 8, 2009 | 02:56 PM
truckdriver_mn1984's Avatar
truckdriver_mn1984
Another issue
Well i mouse has eatin some of the wire insulation off a injector wire... Right above the plug-in for the injector.. Its the front most injector under the throttle body .. Seems like a pain in the *** to get to...
Im sure this is making the truck run rough witch is has been i been f-ing around for weeks trying to get it to run right..
runs some what rough at idle
stalls when you put it in park from driving.
shanks and shimmys going down the road when you use little fuel pressur on the pedal, then if you step down on it, it down shifts rpms go up and it runs great. So i just drive it in D not OD.
Any ideas how i can patch this injector wire up? not really a hole lot of room for a cut and splice. and i dont wanna buy a new harness..
Truck is a 87, F150, 302, 4x4, 3 speed. 1 - D - OD
thanks
Last edited by truckdriver_mn1984; Apr 8, 2009 at 02:57 PM. Reason: forgot trk specs
