RAS system on the front?
Old Apr 8, 2009 | 10:26 AM
fast_fred's Avatar
fast_fred
I put the RAS system on the rear of my 2000 EX V10 along with Rancho 9000xl shocks. Now the rear looks like it’s jacked up compared to the front. Can I put the RAS system on the front to help give it a slight rake look? I'm not really interested in changing to different springs right now and I do have Rancho 5000 shocks on the front I just installed. Just trying to avoid that old 80’s look when people jacked up the rear of their cars to look cool.
Thanks
Fred
Old Apr 8, 2009 | 10:49 AM
71-4R3SONS's Avatar
71-4R3SONS
You must be younger than 40... that look has been around long before the 80's!!!
Old Apr 8, 2009 | 11:48 AM
fast_fred's Avatar
fast_fred
I'm younger than 40. I came in on the tale end of that fad, thank god!
Old Apr 8, 2009 | 12:53 PM
ReAX's Avatar
ReAX
I don't think it will work as well on the excursion's front leafs, I don't believe their is enough arch to pull it in the right direction. If you can't afford the time or money to mess with putting on a leveling kit for the front, you might try taking some tension off the RAS spring. The spec calls for dropping a quarter between 2 or 3 coils. If you reduce it down, it should put less pull on the springs.
Old Apr 8, 2009 | 01:25 PM
fast_fred's Avatar
fast_fred
I need the extra tension for towning, where I have it now works great when I hook up my trailer. The springs on the front are different than whats on rear?
Old Apr 8, 2009 | 02:00 PM
ReAX's Avatar
ReAX
I'm not an expert on the Excursion, but I believe your front packs have either no or negative arch. The RAS only works on positive arch. If you really want to try it, call roadmaster and talk to them, I think Ralph or Dave was my tech contact.
If all else fails, you can get away with something like Fabtech's 2" box kit to level it out without needing new springs or shocks. I'd be weary of the 2.5" as you may need longer shocks.
usmcdaveII
Nov 14, 2013 09:50 AM
Courtney Williams
Jan 7, 2013 09:43 AM
TexasEX2K
Jul 5, 2012 10:46 PM
5Rangers
Jul 25, 2011 09:42 PM
kontoboy
Sep 12, 2010 10:58 PM
