power window
Old Apr 8, 2009 | 09:04 AM
brimszford's Avatar
brimszford
Arrow power window
i have a 2005 supercrew ford lariat 4x4 i am having a problem
front passenger window will go down but not up i have put 12 volts to the motor and it will go up and down no problem i changed the master switch
and checked all fuses and relays. my questions is can the motor still be bad or do i have a broken wire.. i can press the window switch from the master switch and the passenger switch will go dim theres no clicking when you press ther passsenger switch.any info will be appreciated thanks bkm
Old Apr 8, 2009 | 11:55 AM
Fomoko1's Avatar
Fomoko1
Hi and welcome to FTE brimszford.
Sorry to hear about your problem with the window switch, post in the 2004 - 2008 F150 forum for help: https://www.ford-trucks.com/forums/forum24/
Swing by and check out what`s happening n your local Mississippi Chapter: https://www.ford-trucks.com/forums/forum215/
silvergirl
New Member Introductions
Apr 13, 2008 06:50 PM
guthrie&co
Feb 26, 2006 10:51 PM
jesuszlord
Feb 11, 2006 10:08 PM
pest44
Feb 3, 2006 06:32 PM
