Differential gear ratio
I have a 95F150 extended cab with an AOD Transmission, 5.0L engine and 331 differential.
I am looking to get more power as I pull a 25ft fifth wheel dry weight about 4500 pounds.
The truck does great after I get going, but it is real slow starting out. I do not tow in over drive.
If I change the gear ratio in the differential what is the best way to go?
Thanks in advance for everyones help.
