white smoke!!
Old Apr 7, 2009 | 06:59 PM
ford4x4956's Avatar
ford4x4956
Unhappy white smoke!!
white smoke on start up for the 1st couple minutes 2005 6.0.....no power loss, what can it be???
Old Apr 7, 2009 | 07:02 PM
7.3 Rocket's Avatar
7.3 Rocket
You're looking for the forum right above this one.
The one that says 2003-2007 6.0L PowerStroke Diesel
This section here is for the 7.3 PowerStroke.
Good luck getting your problem fixed though.
Old Apr 7, 2009 | 09:17 PM
F350-6's Avatar
F350-6
Welcome to FTE. Do you have a check engine light? You're problem sounds like either glow plugs, or the glow plug control module. The 05 should give you a fault code that tells you which glow plug or module is bad.
Old Apr 7, 2009 | 11:23 PM
ford4x4956's Avatar
ford4x4956
check engine is not on and its now smoking more
Old Apr 9, 2009 | 05:43 AM
megawatt00's Avatar
megawatt00
Welcome to FTE. I moved your thread to the 6.0 forum. These guys will take care of you.
Old Apr 9, 2009 | 11:06 AM
steelhead2's Avatar
steelhead2
pull your egr valve out and look for liquid in the intake.if you see what appears to be oily water in there your egr cooler is leaking.
Old Apr 9, 2009 | 05:59 PM
BADBLUEOVAL351's Avatar
BADBLUEOVAL351
Had the same problem with my 06. Sounds exactly like the turbo seal went and is seeping oil into the exhaust side of the turbo. Mine would smoke on start up until the temp gauge would start to climb. When i pulled away there was a good amount of smoke then it would mostly dissapear. No engine light or power loss, i would bring it to the dealer and have them check it then do it cause it's under warranty still. Good luck and let me know how you make out.
Old Aug 13, 2009 | 04:11 PM
fordboy2's Avatar
fordboy2
where is the oil seal on the turbo? how do I check/fix this? pull the turbo, is it inside the turbo or where the turbo mounts?
Old Aug 13, 2009 | 04:31 PM
BADBLUEOVAL351
It's the seal inside the turbo centersection thats around the impeller shaft. Pull your exhaust pipe off at the turbo and see if there's oil laying in the exhaust side of your turbo
