lug measurement
How is lug measurement determined? Measured from lugs to lug next to each other or lug to lug across across from each other like a star pattern? Thanks.
There's a circle drawn through the centers and it's the diameter of that circle.
So if you've got a even number of lugs there are two you can measure across.
Measure from the inside of one to the outside of another is easier to get it right.
If it's an odd number there are places out there with short cuts written down.
If it's a Ford pickup with 5 lugs then it's called...
"5 on 5 and a half".
5 lugs on a 5.5 inch circle. :)
Dodge used the same for their half ton pickups too.
Whatcha got? :)
Alvin in AZ
MRW - How to measure bolt pattern
I was hoping someone would post it, thanks. :)
And it shouldn't be hard to remember for 5 lug...
"outside of one to the center of the opposite lug"
At least that's close enough to know what's what,
and that's all a guy needs, really :)
Alvin in AZ
