power loss
Old Apr 7, 2009 | 03:36 PM
cutbrain's Avatar
cutbrain
power loss
My 460 loses power periodically. When I stop for 10 minutes it works fine again. This has happened twice both times when the airconditioning stoped working. I have had the fuel pump and filters replaced but this does not seem to fix the problem permanently. Also the engine temp reads ok.
What is going on?????
Old Apr 7, 2009 | 05:46 PM
Bear 45/70's Avatar
Bear 45/70
Bad coil, getting hot and making weak spark. Any ignition box or sensor can do this also.
Old Apr 7, 2009 | 07:13 PM
cutbrain's Avatar
cutbrain
power loss
How do you tell which is the problem?
Old Apr 7, 2009 | 09:31 PM
Bear 45/70's Avatar
Bear 45/70
Change the coil, not fixed. Change the sensor, not fixed. Change the ignition box. Otherwise change and test.
Old Apr 12, 2019 | 06:22 PM
cutbrain's Avatar
cutbrain
God this has been awhile but I ran into my own post. the problem was a bad fuel tank. The corrosion from ethanol fuel, wreaked havoc. Had the gas tank changed and that fixed the problem.
Old Apr 13, 2019 | 01:01 AM
Skitter302's Avatar
Skitter302
fuel restriction caused by a corrosion. thats annoying.
Old Apr 29, 2019 | 12:00 PM
cutbrain's Avatar
cutbrain
Smile power loss
Yes. Fixed by a new plastic gas tank.
