Strut/spring removal??
Old Apr 7, 2009 | 03:36 PM
ALJR's Avatar
ALJR
Need to remove the spring from the front strut on my 05 F150 4wd. Was wondering if I need the spring compression tool to do so?
OR, can I use the weight of the truck to compress the spring (while the whole assembly is still installed), remove the center strut bolt, lower the jack then remove the 3 upper assembly bolts from the frame?
I have dun it that way in the past with smaller passanger cars w/o any issues. Never tried it on a full size truck before...
BTW, I am replacing the front springs only...
Old Apr 8, 2009 | 01:39 PM
VFR_Man's Avatar
VFR_Man
I have seen at least one guy say he did his truck that way when he added a leveling kit that required spring removal. I don't know why it wouldn't work if you're careful and know what you're doing.
Old Apr 8, 2009 | 07:58 PM
ALJR's Avatar
ALJR
Thanks for the reply... Rented the spring compression tool (free from AutoZone) just in case...
BTW, my summer toy is a RC51...
Old Apr 10, 2009 | 09:56 AM
ALJR's Avatar
ALJR
FWIW... Renting the spring compressor is the way to go. Rental is free at AutoZone...
sfc2001
22
May 9, 2023 02:36 PM
mercman86
2004 - 2008 F150
23
Jun 19, 2015 08:45 PM
jbtecnico1
Escape & Escape Hybrid
Oct 10, 2012 04:47 PM
ALJR
2004 - 2008 F150
Apr 10, 2009 08:21 PM
