tranny to bell housing bolts
Howdy,
Just an educated guess but I's say there has to be at least 4. 2 on the upper part of the bellhousing and 2 on the lower, or actually about midway down from the top. Probably take a 1/2 inch socket? If you only find two that would make me think two are missing. If that is the case I'd check all your other bolts, tranny to bellhousing, tailshaft, side or bottom plate bolts and make sure none are missing.
