63 292 motor
Old Apr 7, 2009 | 01:59 PM
Shellvrolet's Avatar
Shellvrolet
63 292 motor
Hi all, I have 2 1963 Ford pickups, one of them has a good running 292 motor with 3 on the tree tranny. The other has a locked down 292 and an automatic tranny. I want to install the good motor in the other truck as it is in much better shape. Im guessing that I need to use the bell housing that is with the auto tranny, pull the bell housing from the good motor that is now a standard tranny and then bolter up??? Will this combo work, Im a newbie F-100 owner LOL Replies Appreciated!
Old Apr 7, 2009 | 04:30 PM
Scifi266's Avatar
Scifi266
What do you want? To switch the 292 onto the automatic tranny or keep the manual? if so you will have to keep the column out of the other truck.
Old Apr 10, 2009 | 06:35 AM
Shellvrolet
292 motor
Yes I want to mate up the good 292 to the auto tranny in the good pickup. A friend said I should just pull the whole thing out, motor and tranny, clean it all up and see what I have.
Old Apr 10, 2009 | 10:54 AM
garbz2's Avatar
garbz2
All will interchange.
Be sure to remove the pilot bearing from the crank. The flywheel from the auto engine will replace the flywheel from the manual engine, reuse the automatic flywheels bolts in the swap as the manual will be too long.
All will bolt to the same front and rear mounts for the engine.
Garbz
Old Apr 11, 2009 | 08:14 AM
Shellvrolet
Thank you
Thanks gents for the replies!
