2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Back up camera or sensors
Old 04-28-2009, 07:18 AM
thinksnow's Avatar
thinksnow
thinksnow is offline
Ok for what ever reason my wifes 07 Limited EL didn't come with back up sensors or a camera. There's a lot of after market products out there. Some looks to be a pile of crap and some looks top notch. I was thinking a camera set up would be nice but then there is the wiring issue. Because of the drop down airbags lining the roof I would be hesitant run wires up there. I've seen a couple of wireless models? Has anyone tried anything yet?
Old 04-28-2009, 10:17 AM
function12's Avatar
function12
function12 is offline
Camera was an option on the 07 limit but I thought the back up sensors were standard. They had 2 different styles. One has the black pieces on the rear bumper and the other used a device that sent the sound waves through the rear plastic bumper.
Old 04-28-2009, 12:37 PM
thinksnow's Avatar
thinksnow
I have nothing that I know of. I have the original sticker and it says nothing about back up sensors. My F250 has the black quarter size sensors but I've never heard of the one sending sound waves through the bumper at least not from the factory.
Old 04-28-2009, 02:55 PM
clearnetedm's Avatar
clearnetedm
clearnetedm is offline
Ya I know for sure my 2008 Expy Limited has the internal method. There are no black sensors on the bumper at all. I'm just not sure if that started in 07 or 08. It ws also standard on the 08.
Old 04-28-2009, 04:04 PM
berry1234's Avatar
berry1234
berry1234 is offline
07's did not come with visible sensors. They used the sonar type system, which is less accurate that the previous system.
Old 04-29-2009, 08:36 AM
trpltongue's Avatar
trpltongue
trpltongue is offline
I just ordered the Sanyo CCA-BC200 backup camera system.
It is really slick in that is uses a computer system to correct the fisheye image as well as projects lines for the width of the vehicle and foot markers at 2, 4, and 8ft behind the truck. It also has an arial view that looks like an overhead view showing the back of the truck.
With regards to the wires, there are aftermarket wireless video senders that you can use to send the video from the back of the truck to the front where the monitor is.
My 07 limited came standard with backup sensors that beep when you get close to something. I believe they can be disabled via the menu so if you don't hear any beeping when backing up (and you're close to an object), check the menu to see if you have it enabled.
Old 04-29-2009, 10:49 AM
berry1234's Avatar
berry1234
In 07, the convenience package was an option on all models. It includes the reverse sensing system, adjustable foot pedals and venting rear panel windows.
Old 04-29-2009, 11:25 AM
trpltongue's Avatar
trpltongue
Good on you! I forgot that the convenience package was an option because all of the limiteds in houston had that included (at least all from the 7 dealers I spoke with did).
Old 04-29-2009, 11:39 AM
berry1234's Avatar
berry1234
Yeah, most Limiteds had that option installed. I have the brochure from 07 that shows the Conv. package as on option on all models.
Old 04-30-2009, 07:00 AM
gddyup's Avatar
gddyup
gddyup is offline
Yep, optional. My 07 EL Limited does not have that package and does not have the rear back-up sensors.
kengarchow
1999 to 2016 Super Duty
09-25-2014 09:28 AM
broncobran68
2009 - 2014 F150
11-08-2012 04:25 PM
i_love_paintbal
1997 - 2003 F150
04-09-2010 12:38 PM
fnx4wheeler
03-12-2010 06:57 PM
Quick Reply: Back up camera or sensors
