I Need Gear/Speedometer Help
Old Apr 9, 2009 | 02:16 PM
Alvin in AZ's Avatar
Alvin in AZ
Mine was out of range and a gear wouldn't correct it. :)
IMO you guys are making this thing too complicated.
-time your speedometer
-pull the gear out, count the teeth
-do some math (post it, I'll do the math?;)
-find out if a gear is actually made the size you need {shrug}
Timing it might find your speedometer is faulty?
Does a C6 lock up 1:1 in third gear?
Different brands of tires are different sizes, enough to matter?
Alvin in AZ
Old Apr 9, 2009 | 02:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by billg302
I was about to post the same question. I found a formula for figuring out driven speedo gear size, but it requires that you know what your tire RPM's are.
Does anyone know what driven gear I need for a 77 F250, NP435 trans, 315/75-16 tires and 4:10 gears?
The problem with giving you the correct speedometer DRIVEN gear part number is...
The tire sizes originally used in the 1970's are all that are listed in the 1973/79 parts catalog.
There were no P-Metric radials available till years later.
I have no clue what a 315/75-16 tire size would be compatible to the tires used in the 1970's.
C1DZ17271A .. 20T Speedometer Driven Gear / Color Coded Black / Available from Ford.
MSRP: $3.07 // FTEpartsguy.com price: $2.21.
Application: 1975/79 F250 / New Process 435 4 Speed / 4.10-1 / 6.50" x 16" tires = See what I mean.
Alvin, Ford said: The difference of one tooth of the DRIVEN gear is between 7 to 10 MPH, depending on the application.
Old Apr 9, 2009 | 02:56 PM
billg302's Avatar
billg302
Bill I see what you mean, it makes sense that Ford would only show specs for factory tires. I do know my 315/75-16 tires are equivalent to 35" tall tires, I don't know how tall 6.50" x 16" tires are. If I could figure out the height difference and knew which way (more or less teeth) on the driven gear to go I could probably get it close. Speedo gears are cheap and easy enough to change that I could make an educated guess and not worry if I were wrong. Thanks Bill for the input.
Old Apr 9, 2009 | 03:12 PM
NumberDummy
I should have typed this in my last post...
Check with a local tire store, they have charts that interchange tire sizes between then...and now.
Old Apr 9, 2009 | 04:32 PM
billg302's Avatar
billg302
I'll do that, again thanks for the help.
Old Apr 9, 2009 | 04:50 PM
billg302's Avatar
billg302
For everyone's info, this is where I found the formula for speedo gear sizing:
Speedometer Gear Color Code Specification Chart With Formulas, And Ford Part Numbers. - Page 4 - Ford Explorer Ranger Enthusiasts Serious Explorations
This forum has some good info on it.
Old Apr 9, 2009 | 10:16 PM
peterbilttrucker's Avatar
peterbilttrucker
NumberDummy... I tried the 19T tonight and I believe it WAS even further in the wrong direction.
Alvin... I timed a mile at fifty seconds (that means 72MPH according to your chart). My speedometer read 57MPH.
1ole4d... I can't find anything about gear reducers on the internet, but then again, I'm not much good with computers either.
Everybody... I have to apologize and embarass myself. Tonight, I noticed that according to the tag on my door, I ACTUALLY have a C4 tranny.
Now, I'm assuming I'm still out of options as far as replacing the cheap and easy driven speedo gears. I asked around town on my deliveries to shops today and found that there's no one left in my area that can calibrate a speedometer. Does that leave me with the only option being replacing the output shaft with the drive speedometer gear? What options are there for that?
Needless to say, I'm a driver, NOT a mechanic.
Thanks guys for being patient with me so far.
Old Apr 9, 2009 | 11:59 PM
NumberDummy
If you reduce your present driven gear by two teeth, the speedo will read between 71 and 77 MPH.
Back then, most speedo's were in-accurate by at least 5 MPH. Ford said that one tooth of a driven gear would add or subtract between 7 to 10 MPH, depending upon the application.
Adding teeth slows down the speedometer reading, subtracting teeth speeds it up.
Tonight, I noticed that according to the tag on my door, I ACTUALLY have a C4 tranny. YOU DO NOT!
ACH du LIEBER!!
(sigh) Your truck DOES NOT have a C4 transmission!
Where the heck did you come up with that malarkey?
It's a C6.
No V8 F250 on the planet ever came with a C4! Some 1965/72 F250's with 240 I-6's used C4's.
The Warranty Plate TRANS code is G.
From 1960 thru 1978, Ford used that SAME fracatta G code for ALL automatic transmissions on car/truck Warranty Plates, regardless of what A/T it was.
This means that G stood for a: Ford-O-Matic, FX or MX Cruise-O-Matic, FMX Cruise-O-Matic, C4, C6 or even a JATCO = Japanese Auto Trans Co. This trans was used in some Ford taxi-cabs.
Back then, one had to know which A/T came with which engine. There was a Ford ID tag on all A/T's which when decoded told exactly what it was.
Most partsguys/mechanics could eyeball an A/T and know exactly which one it was.
1979 was the first year Ford used a specific code for the C6, which was the letter K.
C4 = 11 transmission pan bolt holes / The C6 has 17.
Old Apr 10, 2009 | 01:06 AM
crazedfox's Avatar
crazedfox
Ah,
__crap.
What's point of being accurate then?
Just get the darn thing dialed in as
close it will go, & be done with it.
Old Apr 10, 2009 | 09:08 PM
peterbilttrucker
ACH du LIEBER!!
It's a C6.
Ah, thanks again for being patient with me NumberDummy! I will have a parts guy at alocal dealer decode the plate (I'll take it off the tranny and drive it in to the shop) so he can get me the right output shaft then. Glad it didn't have a C4... I DID come up with that because of the G on the warranty plate. I can't reduce any more teeth from the driven gear because I already have the 16T and they don't get any smaller, right?
Thanks, Ryan.
Old Apr 11, 2009 | 03:27 AM
NumberDummy
I will have a parts guy at a local dealer decode the plate (I'll take it off the tranny and drive it in to the shop) so he can get me the right output shaft then.
You are wasting your time, because that trans code won't tell you diddly squat.
I can't reduce any more teeth from the driven gear because I already have the 16T and they don't get any smaller, right? Right.
The decoded ID number on the tag (the prefix is PJA - followed by a suffix) will only say C6 and give the transmission parts list section of A70.4
When you go to parts list A70.4 there are two different output shafts listed for your application.
But the code plays no part in pointing to which output shaft you have now.
You have to know what the present tooth count is on the output shaft.
E2TZ7060A replaced: D6AZ7060A .. Output Shaft / 6 Teeth / Obsolete
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
FRED GRANDE FORD in Richmond MI has ONE.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
HAVEN FORD SALES in Haven KS has ONE = 800-748-7803.
PARTS INTERNATIONAL in Farmers Branch TX has ONE = 888-727-0418.
No other Ford dealer or obsolete parts vendor has any.
E2TZ7060C replaced: D6TZ7060B .. Output Shaft / 8 Teeth / Obsolete
ED BENNETT OBSOLETE FORD PARTS in Lebanon PA has ONE = 717-272-8762.
No Ford Dealer or other obsolete parts vendor has any.
Old Apr 13, 2009 | 11:32 PM
peterbilttrucker
Thank you for that info... we'll see what happens.
Ryan.
Old May 3, 2009 | 02:01 PM
  #28
peterbilttrucker
Well guys, I found a place that can calibrate my speedometer... it should get done this week and it's cheaper than replacing an output shaft. What makes it even better is that it's the last thing my truck needs to be done. Thanks for your help.
svemike
53
Oct 19, 2016 12:42 PM
catneck
Jun 4, 2016 05:21 PM
Gary Lewis
26
May 3, 2016 09:41 PM
DLP Performance
1983 - 2012 Ranger & B-Series
Mar 6, 2016 07:07 AM
lavatan
Mar 9, 2012 08:26 PM
