bw1356 problem
Old Apr 6, 2009 | 10:34 PM
whitezombie198's Avatar
whitezombie198
bw1356 problem
i have an 89 f250 with the bw13-56 transfer case. every once and a while, it will pop loud and slip out of gear, so i have to play with the shifter a little and put it back in gear. what could be causing this
Old Apr 12, 2009 | 08:50 AM
master_mechanic's Avatar
master_mechanic
i would check your shifter where it pivots on the bolt in the side of the tranny... the bolts probably loose
