ATF recommendations/4R70W problem
302
4R70W
87K
I recently took a 900-mile trip home for Thanksgiving. No problems, truck ran great. On return trip, about 6 hrs from home, I stopped for coffee. I noticed that the tranny didn't want to shift into 2nd. It eventually would, but only after I backed off the RPMs. This was intermittent. Fluid level fine, fluid appearance and smell all ok. On the highway, no problems, with exception of one time it shifted a bit strangely into OD. Difficult to describe this. Since returning a week ago, I have only had this shifting-into-2nd gear problem a couple times. I have tried to induce it, with rapid acceleration, and slow acceleration, both cold and warmed up. Still I am feeling the slightest double-grabbing in the 2nd-to-3rd shift. I don't know that I would call it a shudder. It is very subtle. It connects, and then connects again within a split second.
I am the 3rd owner. The previous owner told me that he changed out the ATF once, and that the original owner also changed it once, so it hasn't been neglected. Previous owner tells me it has Mobil 1 ATF in it now. I have heard mixed reviews on Mobil 1 ATF.
When it comes to trannys, I don't work on them. I'm don't have a garage right now, and I have never opened up a tranny. I'm wondering what could be going on in there that is causing this. Could there be an electrical issue that is responsible? I'm wondering if perhaps the filter is causing a problem (I'm inclined to say no, since it's been serviced twice, but who knows...maybe they didn't change out the filter with the last change, etc.). Perhaps it is something as simple as getting the Mobil 1 out and something better in.
There are no funny noises...no clunks, whines, or anything strange that I can hear. I could probably get in it right now and drive away without any noticable problem.
Suggestions would be appreciated.
I guess a little shuddering is common in these transmissions. My best advice would be to find a good transmission shop and have them drop the pan and inspect the transmission.
Ryan
