1978 - 1996 Big Bronco
oil pan plug stripped
Old Apr 6, 2009 | 05:49 PM
v8xploder's Avatar
v8xploder
I was checking into an leak under my 87 bronco 302 and I noticed it was wet around the drain plug, I grabbed a 3/4 to tighten it and it spins freely. I have had this truck for 3 years and always change my own oil. Do they make a tap n dye for that big of a hole or do I need to replace the whole friggin pan?
Old Apr 6, 2009 | 06:04 PM
McLeod's Avatar
McLeod
They make an oversized drain plug for this exact reason (HELP item, I think).
You could also use a heli coil thread repair to fix the problem.
Old Apr 8, 2009 | 01:51 PM
BroncoRoadKill's Avatar
BroncoRoadKill
try a new plug cause the threads in the pans are pretty tough. I had that problem with a company truck of ours and just replaced with the factory plug from the dealer. never leaked again.
