Rebuilt C4 problem
Old Jan 12, 2003 | 02:23 PM
nickmobile67's Avatar
nickmobile67
Rebuilt C4 problem
Ok, I have a C4 that was just rebuilt. Shifts fine when cold, but after it's been running for 10-15 min (up to temp I guess) the 2 to 3 shift is odd. 1 to 2 is always fine, but when it gets up around 2200 RPMs in 2nd (normal shift point) it quickly revs up to about 3000 before dropping into 3rd. (vrrrrrrrrrVROOOOOOOO rrrrr) Also helps if you let off gas. I had adjusted the vacuum modulator a while back (shouldn't have) so I replaced it today with a new one. Better than it was, but still there. Wierd. I'm not touching the new modulator because I know it is factory set. I tried adjusting the kickdown linkage aswell. Anybody ever experience this before? Should I adjust the kickdown more? (seems OK where it's at now) Should I just call the rebuilder and have him worry about it? (that is what I'll do if I don't get a simple answer) TIA
Old Jan 16, 2003 | 07:03 PM
joetee10's Avatar
joetee10
Rebuilt C4 problem
Sounds like loose tolerances internally, causing the band to slip. Best thing to do is take it back to the tranny guy. That way if its his fault he can fix it and not blame you for messing around with it first.
Old Jan 17, 2003 | 09:30 AM
rabidranger's Avatar
rabidranger
Rebuilt C4 problem
Get a haynes manual and retorque the band adjustment bolts on the outside of the case. Follow the torquing steps to the letter. Also check for vacuum leaks to the modulator on the tranny.
Old Jan 17, 2003 | 10:37 AM
tw's Avatar
tw
Rebuilt C4 problem
mvvette97
Jan 5, 2015 08:18 AM
jav409
Apr 26, 2008 07:59 PM
itcowboy
Mar 25, 2004 08:33 PM
purplegoat
Nov 10, 2002 03:58 PM
