Brake noise
Old Apr 6, 2009 | 03:08 PM
fremont65's Avatar
fremont65
Exclamation Brake noise
I just bought a '03 Ex and my brakes (usually after I've driven it for a while) vibrate and make noise when braking. They car lot said they just put on new brakes and its the pads and that it should go away. Is this a normal problem with these vehicles. Is there a product to stop this vibration or is it something serious. Thanx.
Old Apr 6, 2009 | 03:24 PM
ReAX's Avatar
ReAX
If they just put on pads, I would go through a break in and bedding procedure just to see if that cures it up. I kind of doubt it will, but it never hurts to try. If you still have problems after bedding the pads, then I would pull the calipers and lube the pins really well. If you have a dial indicator, it would be handy to check the run out on the rotors. Also look for the anti rattle spring clips on the pads.
