Help: Temp guage sending unit
Old Apr 6, 2009 | 12:28 PM
spaceship's Avatar
spaceship
Ive got a 1988 Ford e-350 7.3L IDI when running the vehicle the Engine Temperature indicator light comes on, however the temperature guage reads normal operating temp. Also, when I turn the ignition the "wait to start" light only stays on for 1/8th of a second. And it doesn't seem like the glow plugs are heating up.
Could this be a faulty temperature sending unit? If so then why would the guage be reading normal, whereas the "engine temperature" indicator light comes on? Also can any one tell me where the sending unit would be located?
Thanks.
Old Apr 6, 2009 | 12:36 PM
starmilt's Avatar
starmilt
The glow plugs work on resistance not temps. It sounds like you have 2 or more gps not working, but could also be a ground problem or controller problem. The most common is the gps themselves.
Old Apr 6, 2009 | 08:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Drivers side head, sorta under the AC compressor.
Two sending units, one for the gauge and another for the light.
Yes, I know the engine is the wrong color, but you wish yours was the same.
Old Apr 6, 2009 | 10:28 PM
spaceship's Avatar
spaceship
Great, thank you so much! The fact that there are two sending units explains the discrepancy between the engine temp light and the temp guage.
