HIGH idle
Old Apr 6, 2009 | 11:19 AM
894fseries's Avatar
894fseries
HIGH idle
Ok well my freind has an 89 f250 5.0L camper special and as soon as it fires up, it goes strait to wide open. throtle cable is not stuck/sticking and we've replaced the idle air control motor and still not helping. ANY ideas???
Old Apr 6, 2009 | 11:44 AM
Lazy K's Avatar
Lazy K
Sounds like the throttle butterfly has become detatched fron the spindle.
With engine off look down the throttle body and move the throttle cable lever and check that the butterfly moves from closed to open with the lever.
Old Apr 6, 2009 | 02:02 PM
*2fords*'s Avatar
*2fords*
Does it stay at high rpms at all times, even when driving? If so it is most likely the plentium gasket gone bad. my 92 5.0, did the same thing and it turned out to be the gasket went bad. I cost around 400 to replace it at a shop.
Old Apr 6, 2009 | 02:11 PM
894fseries's Avatar
894fseries
ok well the butterflys are closed as they should be but its a 5 speed so i dont know about going down the road its kinda been parked since it started this problem. i does have a whistle to it when we let it run also. will check the gasket next.
Old Apr 6, 2009 | 06:12 PM
mikehawk's Avatar
mikehawk
Spray some starting fluid or carb cleaner around the gasket areas, and if you hear the engine pick up more rpm then you've found your leak.
