Towing with F350
Towing with F350
I have a '97 F350 dually extended cab with Powerstroke diesel and automatic. Suspect that I have a 4:10 rearend. Just bought a fifth wheel RV with a gross vehicle weight of 13,300 and tongue weight of 2,000 empty. Run empty 90% of the time and mileage is horrible. Thinking of changing rearend to 3:73 to improve my fuel economy when running empty. Tow rating guide says that I will still be within GVWR for the truck. What will this change due to towing performance? Would appreciate any other comments pro or con to this idea. Thanks.
Towing with F350
I would suspect that you are losing most of your mpg to wind resistance and not the weight, you may want to invest in a 150$ air dam befor 500$ in to the rear. the 410s' are most likley 411s' and should put you right in the bottom of yoour peak power curve at highway speeds. Hope this helps and good luck.
DutchB100
01-14-2012 08:15 PM
bubba_v2008
05-16-2011 11:32 PM
