Shocking question
Old Apr 5, 2009 | 05:13 PM
woodyf1's Avatar
woodyf1
Shocking question
I am doing the 9 inch rear diff swap on my 52 I am just about ready to install it but I have a question about the shock location I can weld new shock mounts on the 68 diff and utilize the stock location of the shocks or I can build a xmember to install to the existing locations on the diff any suggestions Havi what do you thnk
Old Apr 5, 2009 | 07:52 PM
Julies Cool F1's Avatar
Julies Cool F1
Hmmmmmm, Scott????You there????? tee hee!
Actually I have a 9 3/8 rear in my 51 (it being a derivative of the 9") and it went in and hooked up without any mods (some brake line and drive line mods of course)!
Of course there may have been frosty adult beverages involved - so hopefully the other guys will be along to confirm or dispute!
Old Apr 5, 2009 | 08:14 PM
Ford52F2's Avatar
Ford52F2
I install a 1971 F250 DANA 60 3.73 ratio DOTA-AK 603124-5. I was able to use my original shock mounts, you will need to grind off the ones on the nine inch, they interfered with the originals. if you need to find out what the pinion angle is before grinding. You flip the original shock mounts around, right on left side, left to right. Find angle, remove, grind, paint, have pinion angle shim made, then install. I kinda painted before checking any interference . I can upload some photo's if you need them
I'm still afraid to get it above eighty, the fifty year old center bearing did not like that kind of speed. Had to limp home. It was falling apart , had to replace it.
Right now thou when I find the time, I'm trying to get the vacumm and timing adjusted.
Regards, Dale
Ford52F2
Old Apr 6, 2009 | 07:30 AM
needhelp49's Avatar
needhelp49
same here i just cut the ones off the axle and swaped sides. useing the origanal ones on the frame.
