door panel
Old Apr 4, 2009 | 09:01 PM
James_24_85's Avatar
James_24_85
door panel
Can any of you guys give me some instructions on how to remove the door panels on a 06 scab. I just ordered some new component sets and have never taken off my door panels before. Thanks
Old Apr 4, 2009 | 09:17 PM
rob188's Avatar
rob188
you know what neither have i, but i believe that there are screws hidden behind little panels that can be removed then you should be able to lift the panel up and then out
rob188's Avatar
rob188
at least thats how you do it on an 06 super duty
Old Apr 4, 2009 | 09:22 PM
Ryan50hrl's Avatar
Ryan50hrl
remove the door handle on the inside....remove the screws around the bottom....take the speaker grill off by prying lightly...then remove the speaker.....and lift up on the door panel
Old Apr 4, 2009 | 09:27 PM
rob188's Avatar
rob188
there thats more discriptive
Old Apr 5, 2009 | 05:38 AM
James_24_85
thanks I will give it a try when I get back still makes me a little nervous.
Old Apr 5, 2009 | 05:28 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL
If the 06 is the same which I think it is... You dont have to remove the entire door panel assembly....i Believe if you just carefully pry the plastic grill from the top to the bottom you should have access to both the speaker and the tweeter mounts.
Old Apr 5, 2009 | 11:48 PM
wildcat99's Avatar
wildcat99
If you ordered from crutchfield, you'll get detailed instructions with pictures. For the front door, carefully pry the grille off then use a 7/32 socket to remove the speaker and like Batteries said, you'll have access to the tweeter hole also.
The rear panels have to come off. First gently pry and pull off the 2 upper trim panels. This will expose two 6mm screws. Remove these 2 and one at the bottom center of the main panel. Next use a small screwdriver to pry off the little panel inside the handle. Remove 2 6mm screws here to remove the handle. Now pry up the power window switch panel and disconnect to remove. This will expose 1 8mm screw that needs removed. Now pull up and out to remove the panel. Pretty easy really.
HTH
(If you are planning to dynomat the door skins, then a whole lot more stuff has to come off)
Old Apr 6, 2009 | 03:25 AM
James_24_85
No I got mine from ebay two sets of kicker components 6x8's with tweeters. Thanks for the info can't wait to try it out. I may pick up a hayne's book so I could see some pictures.
Old Apr 6, 2009 | 03:56 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
it's pretty easy man. I just took mine off today
you have to remove the following bolts:
- 2 screws at the very bottom of the door panel
- on the door handle, gently pry the access cover off
...- there are 2 bolts, remove those
- gently pry the speaker cover off
...- remove the 4 speaker bolts and unplug pigtail
...- there are 2 round plastic things that the bottom speaker bolts go through...pull them out
- gently lift the window/lock panel up
...- unplug the 2 pigtails and set the switch panel aside
...- remove the bolt attatching that frame to the door (same size bolt as the ones for the door handle)
once you have all that removed, gently lift up on the entire panel. it will just pop off. then feed the door handle through the door
hope that helps.
Old Apr 6, 2009 | 04:59 AM
James_24_85
should thanks for all the help
Old Apr 6, 2009 | 01:06 PM
wildcat99's Avatar
wildcat99
Don't pry off the speaker grille on the rear door of a SuperCab!! It won't come off like the front door, it's built into the main door panel.
Old Apr 6, 2009 | 01:35 PM
Sethw3's Avatar
Sethw3
Here is a link that refers to replacing the power window motor. They are replacing the back door and it is good for the pictures since the same process applies to get to the speakers. The front grills pop, off the back doors do not.
How To Repair the Power Window Regulator / Motor .: Ford Truck Articles
