6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
regeneration
Old Apr 4, 2009 | 08:09 PM
trucking-guy's Avatar
trucking-guy
regeneration
Does it harm the engine to turn it off before the regeneration cycle is complete?
Old Apr 4, 2009 | 08:40 PM
Larry NCKS's Avatar
Larry NCKS
No. However, you may wish to let it idle and cool a bit first.
Old Apr 7, 2009 | 06:17 AM
senix's Avatar
senix
You do need to let it complete sometime though otherwise it will just come back and may evently tell you that you must do it.
Old Apr 7, 2009 | 02:44 PM
caprang's Avatar
caprang
If you arent able to complete the regen definitely let it idle a bit to cool down. A regen will create upwards of 1400 degrees EGT and they generally recommend cooling down to 500 degrees or less before turning the engine off.
