Squeaky brakes AGAIN
Old Apr 4, 2009 | 10:41 AM
61 uni's Avatar
61 uni
Put new pads on my truck bout a month ago. They never squeaked until then. It is the drivers side front and driving me crazy. Why only the drivers side? Doesn't do it all of the time. If I get on the brakes hard the squeak is worse. I pulled the pads back off thursday and lubed the pins and it still does it. Any ideas? Pads? Rotors? Tired of it sounding like a drive a POS.
Old Apr 4, 2009 | 10:50 AM
Ponyboychris's Avatar
Ponyboychris
I would look at the rotors. probably has a groove in it. Just like a needle on a record. (remember what those are???).
Old Apr 4, 2009 | 10:59 AM
61 uni's Avatar
61 uni
The passenger side has a bigger groove in it and it doesn't squeak. Would softer(cheaper) pads help any. BTW I have some old Alabama records somewhere.
Old Apr 5, 2009 | 09:18 AM
61 uni's Avatar
61 uni
Anyone??????
Old Apr 5, 2009 | 09:44 AM
DieselCamper01's Avatar
DieselCamper01
What kind of pads did you put on? My experience is the harder the pad the more likely to squeal. NAPA pads have been terrible for me on other vehicles. I will not even put them on my truck.
Old Apr 5, 2009 | 09:56 AM
Ponyboychris
I'd say if you have the time and access to a trusted shop, take the rotors in and have them turned. You'd be amazed at the slightest blemish can cause some of the weirdest noises. Double check the pads as well for any type of uneven wear or grime that got caught between the pad and the rotor surface.
Old Apr 5, 2009 | 11:23 AM
61 uni's Avatar
61 uni
Advance wearever gold
Old Apr 5, 2009 | 12:00 PM
DieselCamper01
I don't have any experience with Advance stuff. I do not even have one very close to me.
Old Apr 5, 2009 | 01:23 PM
milleroutdoors's Avatar
milleroutdoors
I had a similar issue.evrytime I applied the brakes, sounded like a Kenworth truck after I had them replaced. After a couple hundred miles it just stopped. Brake shop said "ceramic" brake pads take a few miles and usually wear through it. Sounded kind of " hoakey" to me but they are now quiet. Maybe the same for you
Old Apr 5, 2009 | 04:27 PM
61 uni's Avatar
61 uni
It's been a couple hundred miles now. Anyone have a writeup on removing the rotors on a 2wheel drive dullie? Picts would be great
Old Apr 5, 2009 | 04:32 PM
61 uni's Avatar
61 uni
Forgot to mention the brake padal makes a farting noise when I release the pedal. Any ideas on that one?
