Sponsored by: Real Truck
A/C compressor clutch
Old Apr 4, 2009 | 08:49 AM
995.4SD's Avatar
995.4SD
Ok, over the winter I lost the clutch plate off of my compressor clutch on my 5.4. Don't know how exactly it happened, some how the bolt backed out and the plate eventually fell off. I have the new plate and getting ready to install it. I don't have the old shims to adjust it but I planned on scrounging some up around the garage...my question is, what are the downfalls of having it fully engaged all the time. It is pretty annoying having it engage and disengage all the time, it seems like mine will disengage/engage every few minutes. Im sure there are downfalls for adjusting it wrong to keep it engaged constantly I just don't know the system. Thanks for the help!
Old Apr 4, 2009 | 09:15 AM
senix's Avatar
senix
fully engaged= running all the time. Does impact the life of the compressor and you mileage. Not really that noticeable on the mileage though.
Old Apr 4, 2009 | 12:02 PM
Furian's Avatar
Furian
You Keep What You Kill
I would think that if it engaged 100% of the time that you would lose temperature control... maybe I'm wrong.
Old Apr 4, 2009 | 12:35 PM
dchamberlain's Avatar
dchamberlain
The clutch is controlled by the a/c cycling switch in the suction accumulator. It's purpose is to maintain the evaporator coil at a pressure that will maintain it's tempurature at slightly above freezing. If you allow the evap coil to go below freezing frost will build on it until it is blocked off. Having the clutch always on will cause the evap coil to drop below freezing, which will cause it to build frost, until it is blocked and no air can flow through it.
Also, the clutch will be disengaged by the Dual Function Pressure Switch. This is a switch on the high pressure side, that prevents excessive pressure that will damage the a/c compressor.
So, in short, the clutch is pretty mandatory.
Cab temp control is achieved by moving the blend door between the evap coil and the heater coil.
Old Apr 4, 2009 | 03:30 PM
995.4SD's Avatar
995.4SD
That pretty much sums it up, shims it is! thanks!
Old Apr 5, 2009 | 06:11 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think, even without any shims, the clutch will slip when it's not energized. The problem of course is, it'll overheat the clutch in no time because it will rub.
Old Apr 5, 2009 | 07:39 PM
carls 250's Avatar
carls 250
You can get the shims @ the parts house. Needs to cycle of & on or you will be digging very deep into the pockets.
