DeenHylton--regearing question
Old Mar 15, 2001 | 08:53 PM
pwrstrker's Avatar
pwrstrker
Old Mar 27, 2001 | 05:27 PM
litho's Avatar
litho
Posted this message a few days ago and have not checked the postings for awhile. You wanted to know theaxle code for my rear axle before answering my question. Axle code is 19. Engine is 351 w/ automatic trans. Is it worth re-gearing to tow a 19-20' travel trailer (new and lighter)? Someone else mentioned performance exhaust system--how about that? Thanks for any help.
Old Mar 28, 2001 | 07:17 AM
DeenHylton's Avatar
DeenHylton
>Axle code is 19.
>trans. Is it worth
Your axle code shows you have the light duty rear axle...1723 lb. capacity (the heavy duty axle is . I would double check with your local Ford dealer but I think your maximum trailer weight would be 3,500 lbs. according to the charts. If your truck does not have the super cooling and handling package your definetly factory rated at 3,500 lb. maximum trailer weight.
As far as headers/gearing goes...either one will help. You will notice the biggest difference with the gear change. If you job the work out, headers with dual exhaust or a rear axle gearing change will cost you around $600 each. If you have a 4X4 figure on $1,200 to change out both gear sets.
You asked "is it worth it" to make these modifications? That all depends on what YOU can live with...how fast do you really want to climb the hills? Is it worth $600 to YOU to be able do 50 MPH instead of 40 MPH when going through the mountains? If you go from 3:55's to 4:10's is it worth the extra exceleration to lose
1-2 MPG? I tow 8,000-9,000 lbs with a F250 460 auto...It was worth it to ME to add headers, dual exhaust, K&N air filter, and RV cam to keep ahead of the "pack" when going through the mountains (60-62 MPH), the only time "they" can get around me is only on the steepest grades (50 MPH @ 5,000 ft. elevation). I do have a used set of 4:10's laying around that I have NOT put in because 99% of the time my "combo" is adequate and I don't want to lose any more MPG...I currently get 7.5 MPG when towing, 11.5 empty.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Mar 28, 2001 | 11:21 AM
litho's Avatar
litho
Thanks for the info. I really appreciate it.
Litho
