how high?
Old Apr 3, 2009 | 05:44 PM
2005f-150's Avatar
2005f-150
how high?
how much lift do i need to clear 36-38" tires on a 77 f-250 with f-350 springs? also what is the best way to lift the front?
Old Apr 3, 2009 | 05:47 PM
2005f-150's Avatar
2005f-150
it's a 4x4
Old Apr 3, 2009 | 05:48 PM
flcracker9's Avatar
flcracker9
36" tires should just about fit with no lift, unless your springs are sagging. 38's should fit with a 3" body lift or a 4" suspension lift. There's only one way to lift the front - "New Springs"
Old Apr 3, 2009 | 05:51 PM
2005f-150's Avatar
2005f-150
ok thanks for the help
Old Apr 4, 2009 | 02:52 PM
lasthighboy's Avatar
lasthighboy
is it an early 77 (highboy) or a 77.5? if its a later one you will not fit 36's stock. a highboy you probably could. and you really wouldnt have to lift it to clear 38's. Bushwacker cutout flares. 400 bucks. done.
