Hei upgrade help
Old Apr 3, 2009 | 09:14 AM
79f100six's Avatar
79f100six
Hei upgrade help
So i decided to get rid of the duraspark in my 78 f250 and put in a hei ignition module. But i wanted to know is where there is a resistance wire because the coil is only getting only like 8 or 9 volts, and i have no ballast reisistor. I already did the hei upgrade on my other truck and since it couldnt find the wire i just used the old coil wire to trigger a relay so i could get the 12 volts to the module. But i didnt want to do it on this truck since i already have 10 relays and dont want to add more more.
Old Apr 3, 2009 | 11:04 AM
73FOMO's Avatar
73FOMO
On my truck the resistor wire was in the main harness loom, but with the HEI you just need a 12v hot ignition source to the module....no need for relay, etc.
