Towing w/ high gears
Old Jun 16, 2001 | 11:11 AM
treefort's Avatar
treefort
I have a 1990 F-250HD 4x4 with 351W and 3.55gears 5sp ZF
original EVERYTHING
the performance is not there at all!
and am considering changing the gears,
I have put everything new on this engine and the only thing
left is the EGR valve is registering as bad, check engine light on.
But back to the gears I am going to put in 4.56 gears because in the winter I run 34" tires for the muddy terrain.
But at other times I don't do much highway driving at all
and when I do it is just towing at around 60 mph.
will this gear change make much difference at all and if it will a notciable difference??
thanks,.
any ideas appreciated
Old Jun 18, 2001 | 02:05 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
treefort, I would think it would make a noticable difference.
Here's a link to a gear calculator that should give you the info you need to choose the gear ratio that's right for your truck.
http://www.4lo.com/geartable.html
Old Jun 23, 2001 | 07:24 AM
DeenHylton's Avatar
DeenHylton
Gollott7
6.7L Power Stroke Diesel
Sep 9, 2012 06:02 PM
fairchdr
21
Oct 14, 2011 04:14 PM
Pickupman2004
Oct 29, 2007 05:39 PM
electrified_cc
Jun 25, 2007 03:15 PM
furrby
Jan 27, 2006 08:30 AM
