wiring help
Old Apr 1, 2009 | 09:17 PM
1eyedjack's Avatar
1eyedjack
wiring help
Anyone know of a good website that shows pictures of all the wiring diagrams of a 77 F150 2wd? I want to re-wire everything in my truck but can't seem to find a website other than LMC. DC doesn't have anything.
Thanks
I would rather push my FORD up a hill than drive a chevy down it.
Old Apr 1, 2009 | 10:10 PM
Holiver31's Avatar
Holiver31
bronco graveyard or macs maybe
Old Apr 1, 2009 | 10:50 PM
fmc400's Avatar
fmc400
MSEE
Autozone's website, Chilton's, Haynes, Ford shop manual, you name it. Can I ask what's wrong with the truck?
Old Apr 3, 2009 | 11:37 AM
73FOMO's Avatar
73FOMO
I used a Haynes to sort through and update all of my wiring...so far so good...cut out alot of what I didn't need, and added alot of new wire as well. One thing that is difficult is tracing page to page and it includes wiring for all options and your truck may not have all options. I studied for several weeks and then started cutting open the harness and studying more. I created my own schmatic that was much cleaner with all of my new wiring during the process. If you have patience you can work through it. I would suggest to photocopy each of the pages and try to piece together the entire schematic.
Old Apr 3, 2009 | 12:07 PM
kingford72's Avatar
kingford72
get the factory ford manual on cd-rom from detroit iron you'll find the exact same wiring diagrams as the haynes manual but they don't give you everything you see on the haynes a # like c-330 theres a chart on the bottom of the factory wiring diagram that matches up the #'s and will tell you that c-330 is a green 6 wire conector each color wire thats in it and where its located on the truck like driver side inner fender by cowl.
Old Apr 3, 2009 | 10:09 PM
1eyedjack's Avatar
1eyedjack
thanks for the info guys!!! this place rocks!!!!!!!!!
