Delaware Chapter Join Chapter, Leader:
April B/S Chat Thread
Old Apr 13, 2009 | 04:21 PM
  #781
67nukeford's Avatar
67nukeford
Veteran: Navy
Originally Posted by savage2211
O sorry man. It is a pickup camper. It goes in the bed of your truck,and with an extension hitch you can still pull your boat.
Okay. I've considered one of those also. I wonder if the hitch would handle the boat though, being it's kind of a heavy boat.
Old Apr 13, 2009 | 04:24 PM
  #782
savage2211's Avatar
savage2211
I have seen guys pull a car trailer with one. I guess we would have to check what the weight limit is on the extension.
Old Apr 13, 2009 | 04:26 PM
  #783
Zip's Avatar
Zip
I would think you would be okay with that weight.
Old Apr 13, 2009 | 04:28 PM
  #784
67nukeford's Avatar
67nukeford
Veteran: Navy
that is an interesting thought. I might have to poke around and see how that would work.
Old Apr 13, 2009 | 05:24 PM
  #785
fire240's Avatar
fire240
Good evening all.
Old Apr 13, 2009 | 05:29 PM
  #786
drunkdave's Avatar
drunkdave
evening every body, I think I found the major problem involed with my "heat soak problem."
  #787
glruff's Avatar
glruff
FTE Leadership Emeritus
Originally Posted by Zip
I just want to get out and start camping. Or I guess the correct term would be RVing. I have seen quite a few on the highway today. Probably returning from their Easter weekend trips.
We'll save you a spot at the All Truck Nationals
Old Apr 13, 2009 | 05:30 PM
  #788
fire240's Avatar
fire240
Thats good to hear Dave. What was it?
Old Apr 13, 2009 | 05:31 PM
  #789
fire240's Avatar
fire240
Evening George. Did my taxes today. Lets just say the government is happy.
Old Apr 13, 2009 | 05:34 PM
  #790
drunkdave's Avatar
drunkdave
the ground wire from the battery terminal, that runs to the engine block. dosent ground. Somebody at some point some spliced a peice of 12 gauge wire, to the negitive post to the core support.
Old Apr 13, 2009 | 05:36 PM
  #791
fire240's Avatar
fire240
I have seen things like that before Dave. The ambo comes to mind although it is not that bad.
Old Apr 13, 2009 | 05:42 PM
  #792
drunkdave's Avatar
drunkdave
I got stuck at work, because it wouldnt start. couldnt figure out why the groung on the block is no good, so I ran a piece of 4 guage to the core support for a temp, fix. Turns over a whole lot faster. I still think there is a little bit of a heat issue, but I can start it when it is hot.
Old Apr 13, 2009 | 05:44 PM
  #793
fire240's Avatar
fire240
Which is always a good thing. My first truck would vapor lock on me if the temps got too high outside and under the hood.then again the fuel line from the pump on the block to the carb sat less than an inch above the valve cover.
Old Apr 13, 2009 | 05:52 PM
  #794
drunkdave's Avatar
drunkdave
I think it may be time to invest in rewireing the whole truck. It starts when its engine hot, but it turns over slower than when its cold.
Old Apr 13, 2009 | 05:54 PM
  #795
fire240's Avatar
fire240
probably wouldnt hurt Dave. Who knows how much of the wiring has been hacked up.
