Towing with a locker???
Old Nov 26, 2001 | 10:13 AM
rebelford's Avatar
rebelford
Howdy all, I am thinking about locking up my rear 8.8 axle. I have a 95 ford bronco with a 351 and an 8.8 rear. I go off roading more than I tow. I already have the front Dana 44 locked, Welded the spider gears together. I request the traction off road and Im thinking about swaping a friend axle's for his open and my limited slip. With the open I can install a mini spool or weld it. But my question is would towing my 17 foot boat be a problem. As im not willing to pay for a selectable locker. The art of having all four wheels constantly turning would drasticly improve my capabilities. however is that going to be a problem when I tow?
Thanks
Gary
Old Nov 28, 2001 | 08:15 AM
RJKobbeman's Avatar
RJKobbeman
Well... since you already have your front differential locked, I would say you are only using this vehicle off-road and that you already have experienced the behaviors of a locked diff. The only thing that I can see causing problems (aside from the normal things of locking a diff... but you already have seen that with your front) is that the trailer's tongue weight will add weight to the rear axle. This will put a lot more stress on the rear differential and axles when turning. When off-road and the diffs are locked, the tires slip on the dirt when turning. The added weight on the rear axle will make it harder for the tires to slip...
Old Dec 1, 2001 | 10:44 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
